can anyone give me info or tips on what is the story on this and benefits of this?? I just heard bit about it and I dont have a clue really..
Thanks lads
Thanks lads
wouldn do it lad it will hold moisture and cause rust
It's been done to my car before I got it, supposed to be just as good as seamwelding and the foam itself is solid, the type of foam it is i can't see how it'll absorb moisture but I could be wrong
yea I have heard it reduces drag & increases someting else... Im sure if it was to be done could the holes etc not be fully sealed as in weld them up etc eliminate water from getting in??
all comments are welcome on this 1, as I said I dont really have a clue thats why I am asking, to be educated thanks
Unless you want the car to float I wouldn't :)
It's also toxic if it go's on fire!
used to see alot hondas that came in from jap land that had the sills filled wit it
im guessin its jus bein done to re-inforce sills an chassis legs to stiffin it up
but as said above its toxic if it goes on fire and seam weldin will make the car alot stronger
Toxic.... Yes!!!
Fill them with concrete lad........ It'll stiffen her up and save ya money on lowering springs :wink:
