Some1 with really good knowledge on Power FC's
I put a new throttle body on my rx and used the TPS and intake temp sensor of my old one which were both working fine before dis-assemby.
Now I have put it back together and the power fc under the sensor/sw check screen is reading that there is a fault with the TPS - there is a black line through the readings - which as far as I know idicates a fault, but then engine warning light isnt lighting up which also is suppose to happen when there is a fault with the TPS as far as I know. Also the throttle isnt responding when you pull the throttle it doesnt rev up.
I have been searching on google but cant seem to find info on it.
Does anybody know why it is not working now and it was before I took it apart, I don't understand how there can be something wrong with it when it was in perfect working order
