Are s13/s14 adj rear lower toe arms interchangable??
Thanks :D
Thanks :D
pretty sure no andy, there a completly diffent shape, s13/r32 ones go through the coilover while the s14 ones go around the coilover. could be wrong though!
This is actually a good question....! Im putting a 14 subframe into my 13 soon and its about 15mm wider track with and have to get soilid bushes fabracated because there off centric....!
Think the should but in not certin....!
Standard ones no, but adjustable ones i think will do either, just need a definite answer if anyone knows????
s13 s14 s15 and 180sx are all the same toe arms
s14 bushing is a small bit wider where it bolts onto the subframe but can be chopped a little and bolted up,2 second job.Thats the only difference i found anyway
