if im turning up my boost to 1 bar, wat fuel pressure should i run?
and wat is standard on sr20 2.5 bar?
i think thy're 3 bar standard, must check on sxoc. standard pressure is fine for 1bar if its on standarrd turbo, whats the spec though?
2.8bar...do not ever change fuel pressure
The fuel pressure should be set at 2.9-3.0 bar with the vacume line off and the engine running.
Robbie
