Well lads
Just wondering how to wire up a Apexi RSM. Theres 9 small wires coming out of it. Just need 2 know where the wires has to be wired to.
Im installing it into a R33 skyline gtst.
Thanks
Well lads
Thanks
type in apexi rsm into google . apexi-usa should come up. then go into support and look for the instruction manual for the rsm , then read it!:D
I really don't advise trying it yourself if you are not familiar with doing that kind of work,
There should be a wiring diagram for the rsm in the box for it and you will have to find a pin out diagram foer the ecu then online somewhere.
simples
As said all info is on apex USA , it's been a while, but there's only a couple of wires simple enough, pink and purple are speed cut in and out, the batt ground etc, just go on and get the euc pin out of a r33 are download a r33 fsm
