As above the t25 turbo won't fit onto the stock ca manifold. The compressor housing is hitting of the mani and won't go onto the mounts fully.:confused:
Is there any way of adjusting the compressor housing so it will fit?????:confused:
Thanks, Kyle
Thanks, Kyle
yes, you need to remove the big circlip on the comp housing, give the housing a little tap to free it, rotate it, then put back on circlip, roptate it as little as possible to get clearence but so the actuator rod isnt too bent. use the stock t25 actuator, and youll need top run a vacum from the intake to the actuator as the t25g doesnt have the take off on the housing like the old t25:)
I will be using a HKS adjustable actuator, will this make any difference?
When you say the circlip do you mean the big steel 2 piece gasket with 4 bolts in it??
"the t25g doesnt have the take off on the housing like the old t25"...what you mean buy the take off on the housing??..its a :)learning curve for me
no dude, as long as you dont rotate the housing too muh the hks actuaotr shud fit, no dude, thats not the circlip! itll look like this, youll need a good pin nose pliers or a proper circlip pliers toget it off..
itll look like the big round clip onthe bottom right ofthis pic
http://t0.gstatic.com/images?q=tbn:A...SvrOzSHAaobhNV
the original t25 turbo has a bronze vacum take off on the comp housing to feed the actuator with a boost pressure reading. the t25g doesnt have this, so youll need to feed the actuator with a vacuum feed from the inlet somewhere, i think theres a spare take off blocked under the throttle body...
t25 with take off
http://t3.gstatic.com/images?q=tbn:B...t25web.jpg&t=1
and t25g, see where it would b theres no hole...
http://t0.gstatic.com/images?q=tbn:t...t25g_1.jpg&t=1
no bother tayto!
iv a t25 off a ca on my sr, swap??
