What would you pay for one that is in good condition??
Also its out of a 32GTR so clutch will fit my RB25 so I would imagine the flywheel would aswell??
But then again im not an expert!!
Opinions welcome, well expert ones;)
arent gtr clutchs pull type?
that would be a full clutch kit, the flywheel is part of the kit it all bolts together... you know that yeah ??
id say around 500 would be a good price if its in good condition...
if you get it make sure you get the bearing sleeve etc is with it as there usually different to standard, sometimes the release bearing is thinner, and often the sleeve that bearing sits on is shorter than normal..
prob should be a slave cylinder with it also..
usually with clutch kits ya get all the the gear an fuck out all the standard stuff..
Cool, thanks for that, will make sure I do!!
r33 gtr are pull type aswell,,
