hey im thinking of getting 15mm bolt on spacers whould the bolt be sticking out from the spacer.i whould get 20mm but im trying to avoid rolling the arches.
make yourself a little clearer man, its so vauge as to what you actually want to know...
on an sbody nissan you will have to go 20mm spacer to avoid cutting the standard wheel studs
the studs will stick out a lil bit past a 15mm spacers but some wheels have bit of clearance on the mountin surface so they mite clear them..if not jus trim the extra bit off its a simple job
