The 180sx is driving but i hav no idea how fast its goin as the speedometer isnt doing anything and the rev gauge doesnt work either. Anyone have any suggestions???
I presume you have checked the looms at the back of the clocks to make sure connections are o.k??check fuses and if you have power,earths at the clocks??
had you the gear box out?? if so check the plugs are plugged back into the sensors on the gearbox itself
what clocks have u lad? 180sx kph ones or uk spec 200sx mph????
Could be a dry solder joint on the back of the clocks? Or like has been said if you had the box off are all the plugs back as they should be?
Check the power wires to back of clocks...usually green wire
