Was putting a braided oil feed line on the silvia and while tightening it up on the block, the threads rung.
What do i do now? Anyway of rethreading it and using a bigger banjo bolt? Do i need a new block?
al the exact same after they do it!
cost me €70 altogether..
dnt need change banjo or anything
I drilled mine out wit an Angle drill (a plumber should have one) an tapped it out bigger, then i made an adapter like m16 fine screwing into the block about 40mm long an then tapped to suit the the banjo bolt.
