Oil cooler
well lads, im thinking of putting a BIG oil cooler on my car!!.......but this will put the oil pump under more stress/pressure, so i was thinking of fitting a second power steering pump to the oil cooler line to help pump oil through the oil cooler!!........can any body tell me if this can be done...or will it work
sound lads;)
ive a 34 row oil cooler on my 1jz and its fine...would'nt think there would be any need to fit a secound pump
34 ROW, thats pretty big alright!!...you probably have a fairly new oil pump in your engine though!!.....mines 200km on it!:o i think it could cause a failure!!....but then again if i cant get it cooling better it'l die anyway!:D:D
ya i put a brand new oil pump in before engine was fitted....the car was running nearly 100deg before i fitted it and maybe even go to 110 deg since the big cooler was fitted car runs 70-85 deg max now...well worth it
yea mines at the same craic after a bit of a trashin!!......ah i'l work something out, sound man
