sr20det t518z os giken clutch dejetro pwr fc
As above i have for sale out of my altezza.
(1)SR20det red top brand, new rings, bearings, thrust washers, 1.2mm steel gasket, block and head skimmed and block machine honned, big wing alloy sump, greddy cams 256/264, new oil pump, and mint water pump, all new seals, 740cc nismo injectors. includes altenator and starter.
2350 euro
(2)OS giken single plate sprung clutch with new rebuild kit so everything except the flywheel is new.
750 euro
(3)Dejetro power fc for an s15 with loom etc so you can run it in your 15,14,13 etc. comes with al sensors map and temp and hand controller.
850 euro.
(4)Tomei/greddy t518z turbo mint no ware or play, comes with tomei manifold and turbo elbow and braded oil feed and return. Also has alloy intake for the turbo with no airflow meter for the dejetro setup.
1350 euro
You can ring me on 085 7809132
